![]() | Home > Maintenance & Mods (L322) > Short rear number plate |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Technically, to stay legal the actual plate must be standard size irrespective of the amount of letters.
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
It should be but I’m happy to accept the risk |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
... John
As far as I know there is no size stipulated for number plate dimensions.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
^ sounds about right...
id Read conflicting things about the size but Stan that makes sense.
Unnecessary quote removed
MisterT Member Since: 08 Mar 2019 Location: Lincolnshire Posts: 29 ![]() ![]() ![]() |
Here’s a pic of the tailgate recess behind the plate, didn’t measure it maybe you can judge size from photo....
the recess isnt very big so a small plate will cover that.. ... - .- -.
That’s much smaller than I feared so should be fine. Now I have the unenviable job of removing the glue from the sticky strips. I used a lot cause I didn’t want to screw it on |
I used a hairdryer to soften the glue and most of the strips peeled away then brake and clutch cleaner to remove the adhesive residue |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
My plates are 13" x 4.5" instead of the standard rear plate which is 20.5" x 4.5"... My reg no is 4 digits long and was fitted using standard numberplate screws... ![]() |
