![]() | Home > Technical (L405) > Suspension & Drivetrain Gurus - talk me off the ledge |
| pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 70
So I started with this post a few days after I got my new-to-me 2016 SCV8 back in June. Now that I’ve had it for a couple of months, I can't decide if I have legitimate problems or if I'm obsessing over nothing.
Exactly what Graeme says above sir... |
Thank you both for the advice. Was digging through TOPIx and found a TSB that references the exact clunking sound when accelerating & turning that can possibly be addressed via software update (LTB01076NAS3):
Then again, this only started after they ran software updates for the suspension last time...not sure if the PCM was part of their process or not. Should I bring this up or just push for what GraemeS recommends? 2021 P525 | Eiger Gray |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717
I think i have that clonk noise with my late 2015 SC AB, when setting off from a junction it feels like Im dragging a wheel or something, strangely doesnt do it every set off but sounds really scary at times. Thought maybe a duff tyre but surely I’d feel that when driving at speed.
| Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100
I’ve had problems with the transfer box which produces a grinding noise when applying a lot of lock at low speed.
Update / Recap:
| Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 193
Mine was bumping a bit too much over speed bumps and potholes. Took a look at the 4x4i screen whilst fiddling about and it shows restricted movement of the two offside suspension dampers - so off to the stealers. This could also be your issue. 17 MY Corris Grey 4.4 VAB
| All times are GMT |
