![]() | Home > Maintenance & Mods (L322) > Whine/drone when slowing to a stop - any ideas? |
and it is not coming from the passenger seat ? |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
It's one of those eliminating jobs I'm afraid. You just need to switch things on / off in a sequence, stationary / moving to find it.
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Ha, the passenger seat whine self cured by moving out - long drives are much improved since. My current suspicion is the slowing to a stop whine is possibly coming from the gearbox or possibly diffs or transfer case? I was able to get the noise to stop and start by moving the shifter from D to P to D. I also think I can 'feel' the whine on the gear shifter. I was planning to replace the gearbox filter, transfer case and front and rear diff oils anyway so I'm hoping that either cures it or uncovers what may be the cause. Will also do the mechatronic service bits on the gearbox while the sump is off. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3263 ![]() ![]() ![]() |
I would check transfer box, especially alignment of any props. They do have a shelf life and a oil change may well cure it. |
Thanks dolphinboy. Can you advise how I would check the alignment of props?
It sure how to check alignment. I just remember someone had a transfer box prob (knocking on acceleration or deceleration) and found it was drive train out if alignment but can’t remember where |
Thanks, oils ordered and just about to order new drain/fill plugs too. |
