Home > In Car Electronics (L322) > Android head unit install 2002 -2005 |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 194 |
Finally managed to fit a unit I purchased a month or so ago and been quite please with it, so here are some install pics, details, thoughts and problems.
17th Aug 2019 12:33pm |
Cheers, I did find it the other day and set it for 30 mins. That has lead to having to manually turn the DSP on via the I-BUS now after a boot.... so now need to find the setting for that.
22nd Aug 2019 3:11pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
I use the Tasker app to start the ibus app on boot up. No7 - 2003 V8 Vogue |
22nd Aug 2019 5:54pm |
Does this start the DSP automatically, same a clicking the DSP tab on the I-Bus screen ?
25th Aug 2019 11:04pm |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 154 |
Does this bypass the factory lear amp in the boot? I.e if it doesnt work ( due to fluid ingress) would that matter?
29th Aug 2019 10:20pm |
The I-Bus app and the Resler USB stick and switch the amp on. Without this you won't have any sound. To Bypass the amp and not need these, I believe you would have to do the same as Haylands did in his thread.
30th Aug 2019 12:13am |
I fitted the reverse camera and all seemed OK. I took a live feed from the boot wiring to the reverse light and added a ground and tried it out. It worked perfectly with it switching the head unit on selecting reverse and the picture is pretty good for a £7 camera and was very happy. Coming home late last night and selected reverse and the picture on the screen started jumping. Tried it this morning and fine and all good. Seems having the headlights on is causing some interference, not sure what to do about that... |
6th Sep 2019 11:42am |
parvezsaleh Member Since: 08 Jun 2021 Location: London Posts: 14 |
HI BMG
19th Jun 2021 9:13am |
Hi, I'm far from an expert on these, so this is to the best of my knowledge, but when keeping or having the DSP system, you would beed the I-Bus app detailed above. As I understand it, this switches the DSP on and gives you sound, something the old head unit would be doing. If you keep the DSP, I don't know another way to switch it on. You do seem to be able to bypass it as you've mentioned by wiring the speakers direct.
19th Jun 2021 5:59pm |
Thanks for the reply
20th Jun 2021 12:30am |
think the I-Bus app is the way to go. Remember you need the Resler stick and DSP license when purchasing the app.
20th Jun 2021 9:47am |
I'm planning on installing a reverse camera too, didn't order one with the unit so have asked Eonon for a cost although I think any camera should work so might go for something generic
20th Jun 2021 10:01am |
Quick question about the 6m extension for the GPS - what did you connect it to in the back and what spec extension cable was it?
20th Jun 2021 8:15pm |
LandyNL Member Since: 24 Jan 2023 Location: Home Posts: 1 |
Great Write-up.
15th Aug 2023 7:58am |
