Home > Technical (L322) > Fan on
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Fan on
Goodmorning everyone!! I have a problem, I feel the fan inside the cockpit (maybe the one) stay on all the time, even with the doors closed, it usually stays on for two minutes, then turns off, but now it's always on, ideas?
Thanks in advance
gianluca
Post #527285 7th Sep 2019 7:39am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I would guess it is the FSR that has failed it is a fairly common problem. Mine failed earlier this year it leaves the fan running till battery is flat. I got a BMW one of the internet and replaced it myself with help of YouTube and this forum - it is located behind lower dash panel between steering column and centre console on a right hand drive - quite fiddly to do . 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #527291 7th Sep 2019 8:59am
madcima
I have located the noise, it seems to come from behind the battery, I tried to replace the fsr relay, but without success
Post #527292 7th Sep 2019 9:17am
mpirie
It could be the FSR, not the FSR relay.
The FSR (final stage resistor) controls the fan speed depending on the air flowing over it, so if it has failed then it could be telling the fan to run constantly.
It sits in the ventilation channel below the front fan where the floor carpet meets the floor tunnel, between the front seats and looks like a hedgehog!
Do a search for replacing it in the Wiki.
Done it for you: https://www.fullfatrr.com/forum/topic781.h...eplacement
Mike
Post #527307 7th Sep 2019 12:06pm
V8 Bob
The FSR I fitted is a Merle 64 11 6 923 204
https://www.ebay.co.uk/itm/273722108774?ul...noapp=true
About £36 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #527321 7th Sep 2019 3:35pm
If the fan noise comes from behind the battery it's possible the fan in the fuel burning heater is coming on due to a fault.
To check try removing fuse 59 20A on the glovebox fuseboard and see if the noise stops.
Post #527345 8th Sep 2019 3:17am
V8 Bob
Could it be the ecu cooling fan? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #527358 8th Sep 2019 10:18am
madcima
Update, I spent the Sunday disassembling the car, doing all the tests, and I realized that the FBH is always on, in fact, besides having downloaded the battery, it drank me a lot of fuel without me turning .....
I have disconnected the wires and the noise has ceased, I doubt that the control unit has failed, does anyone know where it is, so as to check it?
thank you
gianluca
Post #527421 9th Sep 2019 6:14am
The FBH is controlled by a printed circuit board located within the casing of the unit itself. These pcb's regularly fail after a number of years.
Post #527428 9th Sep 2019 8:58am
madcima
I understand .... thanks for the information
Post #527429 9th Sep 2019 9:21am
