Home > Maintenance & Mods (L322) > Jacking Up!
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Jacking Up!
Decide to change my front nearside wheel today as the outer tread on the tyre is wearing and my spare is in better condition!
So, lift the car to off-road height so as I can use my new Mercedes bottle jack with adaptor! No use, even with the jack fully extended it didn’t lift the car!
What is the correct procedure to use the bottle jack?
I’ll get the garage to change my wheel on Monday Big Cry
TIA 2014 vogue se
Post #527316 7th Sep 2019 2:42pm
nino_nino
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527317 7th Sep 2019 3:00pm
Baltic Blue
With the car in normal height setting the Sprinter jack easily lifts the car to get front or rear wheels off.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #527319 7th Sep 2019 3:31pm
chefkenmore
I didn’t realise that there’s a piston inside the piston! So only pumped it to the first stage!!
I’ll stick to cooking............................. Rolling with laughter Rolling with laughter Rolling with laughter 2014 vogue se
Post #527359 8th Sep 2019 10:18am
kooky_guy
I had to change a front tyre yesterday after a puncture and had a similar issue! The inner piston appeared to be a bit stuck so it felt as though it had extended as far as it could without lifting the wheel off the ground.
Luckily it freed itself when I tried it again. 2010 4.4 TDV8 Vogue SE
Post #527425 9th Sep 2019 7:49am
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
I personally wouldnt trust a bottle jack on the jacking points just not enough base to be 100% sure it cant rock over, just my humble opinion.
I would favour Nino, method but with a block of wood to spread the load on the suspension arm the jack will stay vertical and there is little risk of it tipping and for good measure stick an axel stand under the jacking point.
Better still is get your self a trolley jack and a pair of stands and lift by the chassis rail about a foot inwards to take the weight of the car abd then a bottle jack to lift the wheel. WIth the axel stand as well.
I tend to crack the door open or pull the air suspension fuse 57 i think, this stops the car from trying to self level.
Hope this helps, safety first!
Post #527436 9th Sep 2019 10:23am
kooky_guy
It seemed pretty stable on the Sprinter jack. Not much option when you're out and about anyway.
I didn't think there were any chassis rails... 2010 4.4 TDV8 Vogue SE
Post #527439 9th Sep 2019 11:04am
Snowy90 L322
I suppose the correct term is rear subframe, old habbits!
Post #527440 9th Sep 2019 11:07am
