Home > Maintenance & Mods (L322) > Vogue air compressor
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Can anyone tell me what the operating pressure for the suspension compressor should be please?
When I activate a height change mine hovers around 9.6 bar if I check it after a run it is normally showing 11-12 bar.
Just lately it seems a bit sluggish to rise to the off road position or to return to normal from access height.
Post #527455 9th Sep 2019 1:42pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I cant help with the pressure I'm afraid, but I ended up replacing my compressor at about 118k miles, on a 2003 TD6. I tried the rebuild kit but it didnt help, so bought new internals and fitted those to the original black turtle shell
My compressor does get a fair bit of use, as we lower it to access height everytime we park up, so for the last 9 years its raised and lowered every time its used.
Post #527464 9th Sep 2019 4:22pm
horsedentist
Yes mine is the same used a lot as the wife is short and not very mobile now we are older. I can monitor the pressure and it’s in the green band but I need to know what it should be reading and can’t for the life of me find it any where.
Post #527467 9th Sep 2019 4:56pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
From the Workshop manual:
'The compressor is used to supply air pressure to the air suspension reservoir. The ECU monitors the pressure within
the reservoir and, when the engine is running, maintains a pressure of:
l 13.7 bar (199 lbf/in2), in systems without an external pressure relief valve
l 11.8 bar (171 lbf/in2), in systems with an external pressure relief valve
You can easily see if you have an external relief valve, it's in the air line from the compressor and usually sits around in the front right corner of the spare wheel well.
This explains it better:
https://workshop-manuals.com/landrover/l32...nsion_ecu/
Post #527469 9th Sep 2019 5:18pm
horsedentist
Thanks for that just what I was looking for.
Post #527471 9th Sep 2019 5:20pm
