![]() | Home > Technical (L405) > How to measure oil dilution |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I understand that the software for the service indicator measures the oil dilution and will indicate that a service is required if the dilution level is outside the acceptable range |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
I am not convinced it measures it rather than calculating the likely value. Having an issue on the wifes disco sport having the service interval for the 4th time in just over a year :O. Current: RR L322 2010
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
Do you use Shell oil ?
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Absolutely. If you want the dilution figure, you’ll need to get a sample of oil analysed. All the car does is count the number of times that the engine’s stopped mid regen and then guess the level of dilution from there. There seems to be no connection between oil change frequency and crank failure on V6’s (this subject has been done to death on Disco 3/4), it just seems down to chance ![]() |
My understanding is that a software upgrade last year was responsible for increased frequency of services being indicated because it increased the sensitivity of the system to oil dilution.. Certainly this is what I was told by Land Rover customer services.
The condition of the oil as regards dilution is not actually measured on the car.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3925 ![]() ![]() ![]() |
I get "Service Required" when I start up but the car was fully serviced only in January this year and has done only about 8k miles since then. Given the uncertainty (there doesn't seem to be a reliable way of knowing if the oil is compromised) is it simply best just to get the oil changed or am I missing something.
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
In the last 5 years I have run 2 x RRS L494, 1 FFRR TDV6 3.0, and now a FFRR 4.4. All have been back to the dealers with service required messages on average every 3k miles and all have been under warranty. Bar the 4.4 all the other vehicles have had, under request, the oil dilution levels checked and apparently each time they were within tolerance under 6.1pc. Various software updates were carried out to reduce the dpf sensor sensitivity (to no avail) and no oil changes were carried out.
I would take it to the dealers but guessing if your profile is correct you shouldn't be affected as thought it was only the newer engines with the adblue that had this issue? Current: RR L322 2010 Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB |
Sods law in a good way - just ordered 10L of oil and a filter - message gone! Geoff |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
the message is probably still there , its just decided to keep it quiet for a while
Yep it came back!!! Geoff |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I get the service required message on my SDV8 4.4 around every 3k miles since I retired and don't do many long journeys any more. The dealer said it was due to the lack of prolonged higher speeds over distance which I try to do if I can, as I don't want a DPF failure. I used to do 15k miles a year, now do around 5k. When they checked my oil it was at 8% saturation so had to be changed as over the recommended limit. I does seem stupid that now I do a 3rd of my old yearly mileage I now have to change the oil once or twice a year between services, all so an engine can meet emission regulations. True what they say though, I'm pretty sure my next car is going to be a petrol engine, but I don't want an SVR gas guzzler and as I like to buy my cars around a year old , I'll have to wait for a 2nd hand 4L petrol FFRR as they've only just come out. This will at least avoid the DPF, diesel in oil and not enough long runs scenarios relating to diesel engines. Steve
