Home > Technical (L405) > [Solution] Keyless entry relay theft
andygts
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
 Current
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #527605 10th Sep 2019 8:22pm
Ukandrewf
Censored --
On my third Full Fat RR
there's nothing like it.
Post #527606 10th Sep 2019 8:26pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
On my seventh FF, 1979 to date, yes they're good, but not without issue. I believe LR hit a high point with the L322, but the next L405 model kicked in with problems.
Post #527612 10th Sep 2019 8:50pm
Ukandrewf
i think all new models have issues. the best advice is not to buy the first of a new model. let them find and fix the problems for you first...
i bet the first L322 had issues when it first came out.
Andrew --
Post #527616 10th Sep 2019 9:02pm
roberlar
I bought an L322 brand new in 2004. Unbelievably it had no problems at all in the fourteen years I owned it. Yes, it had a couple of years grace following introduction, however this isn't a valid excuse for the model to exhibit certain issues, and quite clearly this forum shows problems do exist way beyond the introduction post 2013. That said, we all have the choice,.
Post #527617 10th Sep 2019 9:18pm
supershuttle
My tin isn’t perfect but it does reduce the range of the signal Geoff
Post #527654 11th Sep 2019 9:38am
Ukandrewf
for £7 for two pouches which are 100% effective why not get the real thing to protect such a high value asset? just saying...
maybe the tin is easier
i thought the pouches would be a faf but actually they're pretty easy and protect key from scratches etc.
Andrew --
Post #527761 12th Sep 2019 8:19am
supershuttle
Actually I disabled keyless - much better - it was a solution looking for a problem. It looked so hard it created one, L405s with keyless are too easy for thieves to get inside. Geoff
Post #527779 12th Sep 2019 9:24am
its kinda satisfying that when you press the keyfob and the mirrors go in that its positively locked... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #527781 12th Sep 2019 9:35am
Ukandrewf
This is probably the most sensible solution.
Andrew --
Post #598962 28th Jun 2021 12:16am
