Home > Maintenance & Mods (L322) > 3.6 TDV8 inlet manifold repair |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Another close up
15th Aug 2019 5:54pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I’ve just sprayed soapy water all over it and no bubbles. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
15th Aug 2019 5:58pm |
I’ve had a smoke test done but nothing came out of the manifold
15th Aug 2019 6:05pm |
Just tried it hot
15th Aug 2019 6:54pm |
Looks like all that is fine. Mine had some smoke marks on the cover.
15th Aug 2019 6:59pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
So my jb weld is still holding up after 2 weeks and just short of a thousand miles. It certainly looks like it is only the drivers side that fails so if/when mine fails I’m just going to replace the one unless there is a spate of passenger side failures by the time I need to do it
16th Aug 2019 10:40pm |
So my qbond lasted a week or so but was leaking again. Chipped what I could and now used puraflex u40 which is the same as sikaflex apparently. Will see how that goes. Current 2007 TDV8 Vogue Buckingham Blue |
24th Aug 2019 4:38pm |
Well my repair has failed today, 3 weeks and just shy of 1500 miles and I got the restricted performance bong along with the P023 code. Oddly it was on the exact same place on the same road as the first time, I pulled into the same lay-by to reset. I now expect to replace the manifold but will try Sikaflex first.
25th Aug 2019 6:10pm |
Sikaflex repair failed yesterday so I've concluded that there isn't an easy fix for this, I'm sorting a new manifold this weekend. |
4th Sep 2019 2:02pm |
I've ordered a new one as well as I don't think the sikaflex is holding but will check again at the weekend. eBay have a 10% code today for using the android app so brought the pain down to under £300 for the new manifold. Current 2007 TDV8 Vogue Buckingham Blue |
10th Sep 2019 5:20pm |
I reckon you’ve confirmed that this isn’t a long term fix.
10th Sep 2019 8:57pm |
