Home > Wheels & Tyres > Discovery 5 wheels?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Discovery 5 wheels?
Does anyone know if they will fit my 2004 FF?
I have a set with winters spare, and was hoping I could use them rather than buying a new set.
Thanks
Post #527947 13th Sep 2019 8:09pm
chugga90
Should fit, pcd is the same.
Would check the load rating, as the D5 is lighter than predecessor.
Not sure which date wheel nut size changed on L322? So check your nuts fit! Whistle
Hopefully this helps?
Post #527953 13th Sep 2019 9:20pm
philip1972
Very helpful indeed, I will check the nuts Thumbs Up
Post #527954 13th Sep 2019 9:30pm
If your nuts are black "ooh err" then they won't fit the D5 wheels... If your nuts are stainless then they should be fine... They changed on a 05MY> (Jag era) Thumbs Up
Post #527957 13th Sep 2019 9:45pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I’ve got some Discovery 5 wheels on my 2007 MY with no problems but as said earlier you’ll need to check your wheel nuts.
Post #527963 14th Sep 2019 3:34am
