Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, pm sent. 2012 TDV8 Black Edition
13th Sep 2019 10:07am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3692 |
13th Sep 2019 7:13pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Thx Nino.
13th Sep 2019 9:42pm |
bit of a sore point Nino, Greg and vacuum pumps, but I would suggest, if it is old design with nut on top, just remove nut, or at least undo it to the top of the thread so that you can try levering it up a bit to work in plenty of WD 40.
14th Sep 2019 10:08am |
14th Sep 2019 10:38am |
Ok front undertray off (geez a lot of bolts on that front one, only three for the middle one for oil changes)
14th Sep 2019 2:10pm |
that is correct Greg, it is stiff, that is normal. 2012 TDV8 Black Edition
14th Sep 2019 2:29pm |
Just got home Greg, how did it go?
14th Sep 2019 7:51pm |
ok so been under again, Nino as you say it's very stiff.
14th Sep 2019 7:55pm |
Just reading the manual, is it me or do they call that same valve different things:
14th Sep 2019 8:03pm |
I have definitely misunderstood what the valve does.
14th Sep 2019 8:40pm |
It's a maze of plumbing alright:
14th Sep 2019 9:01pm |
Ok makes a bit more sense now that I'd been staring at it for bit....
14th Sep 2019 10:14pm |
A quick search for the actuator:
14th Sep 2019 10:27pm |
