Home > Technical (L405) > Homelink - why do Land Rover bother with it???
andygts
Had a play with my new to me L405 yesterday, read up on the homelink and it now does rolling code, read a little deeper and typically my gates (BFT) aren't on the list Censored
I do have a seperate rolling code system wired into the gates, garage and house alarm to put everything onto one fob but still rolling code to make it more secure and it doesn't work on that either Censored
Why do they bother fitting this Censored system? it only seems to work with antiquated fixed code systems.
2hours wasted and nothing achieved Sad
Looks like the fob is here to stay. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #528166 16th Sep 2019 8:04am
I lost several hours of my life trying to get it working too.
Great in theory......
Post #528168 16th Sep 2019 8:18am
Me too! Rolling Eyes
Post #528179 16th Sep 2019 9:14am
mpirie
Same here, it doesn't work with my Glideroll garage door.
Pointless!
Mike
Post #528181 16th Sep 2019 9:30am
TJH1985
The L322 system works at my others half's work, she loves it!
Doesn't say much for their security though Rolling Eyes
Post #528182 16th Sep 2019 9:49am
dfulgo
Italy
...same for me: forced to add the "Homelink" device to my current "Nice" control units. 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue)
Post #528293 17th Sep 2019 7:01am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I’ve spent more hours on this than I care to admit, but have now got a stable working setup.
Complications will sound like first world problems but relate to a combination of multiple garage doors + entry gates. Compounded further by having two cars with homelink transmitters.
The solution has been to give up trying to get the car(s) to work with the doors and gates direct but instead to use a “PR433-4 2-Channel Rolling Code Universal Receiver model PR433-4”. This is a £50 gadget which is hardwired to the door/gate opener and receives directly from the RR homelink transmitter. Need to order from Chamberlain in Germany but arrived quickly and easily.
(There are quite a few internet video guides out there on how to programme Homelink from scratch but the US version of Homelink seems to have some subtle differences so take care if you’re in Europe.)
This is the current link to where I bought the gadget...
https://www.shopssl.de/epages/es10567317.s...ts/PR433-4 2016 SDV8 AB
Post #528298 17th Sep 2019 9:03am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Hi All,
I have on all of my cars and it works a treat, main gates and garage doors, you do however need a homelink box inline though incorporated into your gate system, all of my systems are FAAC and they all work perfectly. I have an excellent engineer who set all of mine up. So I would always spec it.
Post #528303 17th Sep 2019 11:04am
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi
I have a 2011 L322 with Homelink and it works fine with both my garage doors and gates, both of which have rolling codes.
After a bit of experimenting I found the way to get the code in is to press and hold the button on the mirror that you want to code then press the button on the relevant remote repeatedly at a rate of about twice per second. After half a dozen or so presses the little red light on the mirror changes to show it has learnt all the codes. 2011 TDV8 Vogue SE
Post #528346 17th Sep 2019 5:36pm
andygts
I'll give it one last try with that technique, I did have to keep re pressing my fob due to it timing out but it was nowhere near as quick as that.
EDIT
Continously pressing the fob does indeed make the mirror learn the fob.
BUT follow the learn process for the control panel and it still doesn't want to talk.
I've survived using a fob 'til now so I'll carry on using it. Current
Previous
Post #528349 17th Sep 2019 5:54pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
I just set this up tonight on the garage doors. I've also set this up many times over the years on various homes/rovers I've had. Never been an issue.
two ways of doing this.
1.) take your garage/gate remote hold it up to the rear view mirror, simultaneously press and hold the button on the remote while also pressing and holding the button you're trying to program on homelink. You will see the LED flashing slowly, once it's programmed it will begin flashing rapidly and you're good. If this fails you may want to clear the system by holding both button 1 and 3 simultaneously until the light flashes like crazy.
2.) park in your garage... press the learn button on your opener, get back in your car, accessories on... hold the homelink button you wish to program. It'll flash slowly and then once programmed rapidly.
Post #528409 18th Sep 2019 6:13am
EdJ
I can very much relate to this thread. I’ve spent hours trying to get Homelink to work without success. So frustrating. 2024 Range Rover P550e AB
Post #530116 5th Oct 2019 7:25pm
Bill
As an aside some “garage openers” jam types of radar speed detectors ... not sure of the frequency Whistle Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #530184 6th Oct 2019 4:44pm
