![]() | Home > Technical (L322) > Injector removal help |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
25mm spanner, nip the injector clamps up, put a mark down the injector with tippex to ensure the solenoid goes back in at the correct angle, then undo the 25mm nut... just be careful when you take the solenoid off as there is a very small pin that may fall out.. i did this a week or two ago on cylinder number 8, nearest to battery but im sure i read that the other back one will be the same way! 2004 td6 l322 - gone
Ive got to do the exact same job at some point, let me know how long it roughly takes please, had the parts for months just not the motivation! 2004 td6 l322 - gone
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
That's great thanks. I'll do that.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Topix tells us to replace the injector seals pipework (incl leakoff pipes) as they are a one fit stretch/compression parts! They are not cheap but necessary I'm afraid... |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Hi Giles did you manage to do this in the end? I've been told to lift the engine but this seems like an easier way. Current 2007 TDV8 Vogue Buckingham Blue |
Yes, I did manage it.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Sorry!!!
Thanks. Did you have any issues with the injector afterwards following splitting it? Current 2007 TDV8 Vogue Buckingham Blue |
No issues with the injector after I put it back together. I didn't leak and the injector values are good.
Thanks. I'm going back at it today. Did you mark the injector at all to ensure you got it tightened the same when you put the top back on? Current 2007 TDV8 Vogue Buckingham Blue |
Also where do the plastic clips 2 coloured yellow and 2 white go? I didn't pay much attention to them when removing the injectors and can't really see a logical place for them. Thanks Current 2007 TDV8 Vogue Buckingham Blue |
I don't remember marking the injector. When you tighten the 25mm nut down, it comes to a dead stop. I left the 25mm nut finger tight until I refitted the fuel supply pipe. Once it was aligned, I snugged down the 25mm nut. It was less complicated than I imagined.
Thanks Giles. Yes ita the plastic bits that are part of the clamp for the injector. I can't see anyway they would go.
