![]() | Home > Wheels & Tyres > Another tyre thread! 285/55R20 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
I have a set of 285/50/20 Cooper AT on std 20” L405 offset wheels, they catch ever so slightly on full lock - not much just a very faint rub. Therefore the 285/55’s are definitely going to rub, unless you can adjust any steering lock stops to give a reduced turning circle - I’m not even sure the L405 has them like the old RR classic and Defender 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
nikjt76 Member Since: 19 Sep 2019 Location: Newcastle Posts: 2 ![]() ![]() ![]() |
But 285/50R20's are smaller (793mm vs 811mm) in diameter than a 275/55R20 which people often fit with minor rubbing similar to your description, I can't imagine that 5mm further out will outweigh the 9mm increase in sidewall bewtween 285/50 and 275/55
It’s not just 5mm further out though - they are also 5mm further in on the inner wall, and it’s the inner wall that catches.
