Home > Technical (L322) > front prop Q
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
front prop Q
can anyone confirm if the front prop on the td6 also fit the 4.4 ??
ta
Post #528668 20th Sep 2019 10:41pm
RRPhil
Yes, the front propshaft is the same, though the final drives are different (i.e. different ratios: petrol = 3.727, diesel = 4.100)
Phil
Post #528674 21st Sep 2019 12:45am
bembo449
Great stuff , got a bit of play in mine pal so looking for a good 2nd hand one
Post #528701 21st Sep 2019 10:15am
bembo449
Got a replacement front prop , doesnt fit ! Looks like there are 2 types , bolt on or flange
Post #529361 28th Sep 2019 10:09am
RRPhil
Theoretically, there shouldn’t be any 5-speed L322s left on the road with the old-style splined pinion drive tube as they should all have been converted to the flexible joint version under Service Action Q041 which was rolled out in June 2008. Your vehicle, like everyone else’s, should have the flexible joint.
Phil
Post #529368 28th Sep 2019 11:37am
bembo449
oh right , well theory is out the window here Phil , mine still has the old spline type fitment , a fact I didn't know until I went to fit the replacement this morning , can I get round it OR do I just source another ??
Post #529390 28th Sep 2019 2:23pm
RRPhil
That’s amazing that your spline has lasted as long as it has. Generally, a slight misalignment between the propshaft and the final drive unit caused the spline to wear away and eventually fail through fretting corrosion, as huge numbers of us had the pleasure of experiencing.
If the internal spline inside the drive tube looks to be in good condition then I guess you can just replace the propshaft with one of the old design (if you can get hold of one that isn’t badly worn). Otherwise the final drive has to be updated to the revised drive flange design to match the propshaft design with the flexible joint at the final drive end (they all have the rubber flexible joint at the transfer box end). Because the preload on the pinion bearings has to be set properly, updating the final drive isn’t something that you can do yourself, unfortunately, due to the large number of special tools required.
Phil
Post #529425 28th Sep 2019 7:00pm
bembo449
Blimey phil ! Im glad ive only got a tiny bit of play in it then as i cant warrant the cost of changing the lot Confused
Post #529456 29th Sep 2019 9:01am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I would suggest talking to your main dealer. This was a free of charge service action to address a very common failure point. They avoided the term recall for some reason, but to all intents and purposes, that’s what it was. I’m not aware that any time limit was put on the corrective action. You never know your luck - they might do all the work and supply all the parts courtesy of LR. Even lend you a new vehicle for a few days whilst they do it? Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #529459 29th Sep 2019 10:08am
Mikey
There was a time limit on the "Service Action" and it expired many years ago
However, if you don't ask, you won't get Wink
Post #529470 29th Sep 2019 11:29am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Mine failed 7 years ago and the 'recall / warranty' , I was informed , expired the week before. My vehicle was in the main dealers care being driven to the garage when the front prop failed ,and as such they recovered the vehicle at no cost to myself. However it still cost me the thick end of £1000 !
Post #529493 29th Sep 2019 5:04pm
