Home > Technical (L322) > HEVAC help!!!
Vinnylondon
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
HEVAC help!!!
HEVAC help
Nothing works on the panel. Changed the panel nothing works doh.
Advised to change final stage resistor. Doh doesn't work.
Need to do A DIAGNOSTIC is it worth buying a mangoose.
Finally will the unit stop working if the gas has run out.
I thank you all in anticipation and yes all fuses are good.
Bow down Bow down
Post #486900 23rd Aug 2018 11:23am
Check your FSR installation, make sure it is correctly seated, easy to get this wrong
HEVAC will still work if the AirCon gas runs out
Check all your connections to the replacement panel
A diagnostic tool may help... Wink .
Post #486939 23rd Aug 2018 6:14pm
Vinnylondon
Thank you I will check connections and useful to know about gas will update as soon as I can. Thumbs Up
Post #486944 23rd Aug 2018 7:00pm
Vinnylondon
Just a bit of feed back, it was the hedgehog thingy at the back and the number 12 fuse.
Post #528995 24th Sep 2019 10:41pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
So thingy or fuse?
Both were gone?? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529019 25th Sep 2019 10:12am
Vinnylondon
It was the FSR final stage resistor, I changed it but it still didn't work I was scratching my head then decided to have another go at the thingy and
I realized that it was not in its correct seat so after a final push and hearing the quite audible click that announced its final resting place and checking to see if that worked.....nope, scratched my head then decided to check the number 12 fuse of which was a 10 amp. Blown ha ha changed that and it all worked fine for a while but then the fuse will blow again so decided to put a 15 amp in and now works fine.
Post #529025 25th Sep 2019 10:37am
