Home > Technical (L322) > How should the car sit?
dazza1983
So i find myself asking yet another question lol..
One thing that im trying to figure out, i park the car up at work in one of 3-4 spots in our car park and some times the car looks like its sat level front and back and sometimes the car looks like its sat lower at the rear (front raised) ???
How are these suppose to sit? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #529015 25th Sep 2019 9:29am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Level...
If not needs calibration i think.
As i know it can sink a couple cm but level. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529020 25th Sep 2019 10:15am
dazza1983
weird then,
Sometimes it sits level others it sits rear lower? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529026 25th Sep 2019 10:50am
CS
My experience with older RRs with air suspension has been that they tend to sag a bit at the back, not necessarily to the same extent every time, but in general the longer they sit the lower and the longer it takes for the compressor to get them level again once the engine is started. I just put up with it, sometimes one had to wait a while before driving off, but a system overhaul with replacement of poor seals, perishing bags, worn out compressor etc would be the permanent solution. I'm not sure recalibration would solve it, assuming the vehicle gets level when running. Only Range Rovers since 1988
Post #529029 25th Sep 2019 11:05am
I always felt my FFRR's looked like they were sagging at the back, even if the suspension heights were correct (vehicle design / optical illusion / etc.)
I set the rear heights to + 20mm and this seemed to make my eyes happier Thumbs Up .
Post #529030 25th Sep 2019 11:12am
dazza1983
Thought I’d upload a couple of pics instead might be easier lol.
Although car looks more level in pics than in the flesh. I’m wondering if it’s just the ground though?
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529031 25th Sep 2019 11:20am
rjff
Our drive isn't level and slopes gently away from the garage. The car, when across the front of the garage, appears to be sitting with less clearance under its "uphill" side. I've assumed the car justs sorts itself out to level if left alone.
It also does this when I park nose in in certain spaces in the local supermarket carpark. Stick it in P and handbrake on and the front appears to lower. Slight rise of tarmac towards the fence. Cheers
Richard
Gap IIDBT
Post #529035 25th Sep 2019 11:52am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Ours driveway has an odd camber to it and our Rangey never looks like it is sitting level on it whereas it does sit 100% level on a flat surface. Now I know, I just ignore it even though several people have commented that the suspension must be shot when they've seen it on the drive. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #529036 25th Sep 2019 12:06pm
dazza1983
Hmm bradders and Rich’s post almost contradict each other don’t they lol.
I guess I’ll see what she looks like on level ground. I would have thought if there was a suspension issue it would flash up?
Thinking about it I’m the past a couple I’ve noticed when I’ve parked up and walked to the rear of the car I’ve actually heard and seen the rear lower ever so slightly ? After I’ve locked it? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529038 25th Sep 2019 12:27pm
umitbat
Unnecessary quote removed
Looks ok to me.
You can measure how much it sinks what corner but dont bother it will level while driving;) 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529047 25th Sep 2019 2:21pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Sort of related to this post. Our drive is fairly wide, the section in front of the garage is concrete and has a fair slope on it down to the road.
The other half of the drive is gravel and not as steep as the concrete side, but still has a slight slope down to the road.
When we park the car we always reverse it on to the gravel side and the back always appears to sit lower than the front, which it would to keep the body level.
I was told (or read somewhere) that you should not park a RR on a steep slope or say parked half on half off a kerb for long periods as the car will try to self level, and if too much could potentially flatten the battery.
Any truth in this?
Post #529064 25th Sep 2019 4:14pm
dazza1983
The things that co fuse me with these cars why would it try and self level when parked up and locked?
Also mine should be trying to get the front of the car lower as the rear ground is lower. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #529067 25th Sep 2019 4:30pm
PaulTyrer
Because it can!! Rolling with laughter
Post #529074 25th Sep 2019 5:22pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I can relate to your comments, as I often think that mine is sat low at the back although level. Even after it's been sat for a week it looks low, but still level & agree with Joe90's comments.
If you don't have any leaks etc. then all's good Thumbs Up
Post #529094 25th Sep 2019 7:48pm
rjff
Dazza
If you're standing on a slope don't you try to stand upright?? (assuming, of course, it's not you that's unlevel Whistle )
I agree with Paul's comment, and it is a b***dy FullFat after all. Mr. Green Cheers
Richard
Gap IIDBT
Post #529097 25th Sep 2019 7:59pm
