Home > In Car Electronics (L322) > Gap tool interpretation
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
How can I pinpoint the fault shown on my Gap tool , (Auxilary sensor incorrect)
I have had battery problems and Hdc inactive along with intermittent susp. Inactive after changing and recalculation a suspension spring bag replacement , which is quite difficult to do , so not sure what’s going on , any help appreciated.
Post #529191 26th Sep 2019 7:22pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
What's the fault code? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #529233 26th Sep 2019 10:09pm
alfapat
It just says The above in invertered commas.
The fault comes up in Gap tool under Instrument panel.
Post #529236 26th Sep 2019 10:41pm
Rewmer
The problem is that one system can bring down many others. You need to do a clear all and then look at all systems and see what recurs. An abs fault will drag down the suspension No7 - 2003 V8 Vogue
Post #529275 27th Sep 2019 11:47am
alfapat
Yes I know, this fault returns and will not clear . I am going to bite the bullet and buy a proper battery. Inactive warning comeback today and going through the faults, the front right sensor came back after running the car for four days and clearing the fault. Something not quite right when t thinks that I am at full Hightower and warns me that I shouldn’t be over 30mph , when clearly the suspension remains in normal ride height.
Mor info later !
Post #529279 27th Sep 2019 12:16pm
Bushy30
Sounds like the best plan Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #529287 27th Sep 2019 12:51pm
alfapat
New battery installed and much as such has happened again ....especially “Auxiliary sense incorrect” so not sure what that could be .
Post #529397 28th Sep 2019 2:25pm
alfapat
Above fault will not clear.
Post #529398 28th Sep 2019 2:29pm
alfapat
Dash clear at the time , switch off everything and up comes suspension inactive as it closes down.
Post #529399 28th Sep 2019 2:31pm
DrRob
Are you near Dundee? Take it to MMP Land Rover aka Disco Mikey on here Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #529400 28th Sep 2019 2:54pm
alfapat
No I’m not really, in any case O would always try and resolve this myself.
One thing has occurred to me is that Aux sense could be , the clicking I now get when I open the doors. It’s a small motor I believe that resets the air flow behind the dash
Post #529439 28th Sep 2019 8:23pm
DrRob
OK. Hope you get it worked out Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529441 28th Sep 2019 9:01pm
alfapat
That clicking has been resolved which was a stepper motor in the HVAC SYSTEM and quite easily accessed.
Aux sense still a fault . Will not clear
Post #536189 2nd Dec 2019 7:28pm
