![]() | Home > My Range Rover > My new old tired full fat. With a couple of issues. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
That's actually very tidy Rich.
Oh the vanos rattle pull the vanos solenoid out and clean with brake cleaner several times then refit that should help along with fresh oil n filter.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Nowt wrong with that chap! |
I get 240 miles or there about on £45 of lpg no difference in running or performance if your local swing by with it and il put the scanner on it for you and check your lpg at the same time |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Very kind offer.
With the airbags...
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Deathly hallows?
Bit far for you to pop in as im se london junction 4 m25 as for the air bags as it goes down on both sides it looks like both are leaking but there is a valve block drivers side behind the inner wheel arch liner mite be worth checking first.
Deathly hallows? Lol
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
It’s actually pretty tidy for £1300! You could just run it into the ground and would be no worse off, but I think it’s worth a punt on a fix or two. |
She's my aunt. |
If you decide to get rid of it I'd have it for 1300 |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
Al straight forward fixes & Not bad for the price, definitely worth spending a few quid on it. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I would get the battery light issue resolved / checked
