![]() | Home > Technical (L322) > Starting up a diesel |
| gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287
I get the same if I also don’t use it for a few days. It’s the battery and if I use the car daily I don’t get the message. Nothing really to worry about but awareness these things like to be used and are heavily dependent on battery charge. I wait for the light to go out then turn the key. I also switch everything off until engine start.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
The only time I wait for the light to go out is on very cold days in winter otherwise I just start it as you would a petrol engine. Never had any problem, this applies to our other diesel cars as well. |
| dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529
I always turn the key / press the button to position 1 before starting and always have petrol or diesel. I like the idea the car gets a second to sort it’s electrics out before starting.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
I just get in, put foot on clutch and press the button. I never switch it on then press for start.
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
Always wait a few seconds once the ignition is on. Gives time for glow plug to heat up and more importantly allows electric fuel pumps to build fuel pressure 56 TDV8 Vogue SE
| Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282
Always give the system a few seconds to wake up and always let the glow plug light go out before starting . On mine if I don't let the car wake up it throws "u" faults up and needs to be cleared with the iid tool |
| All times are GMT |
