Home > Technical (L322) > Steering wheel not retracting
Andy
I’ve had my TDV8 for 7 months now and I’ve just noticed the steering wheel doesn’t retract when switching off. I think the reason I hadn’t noticed was because I’d disabled this on the TD6 a few years ago and I’d got so used to it not doing it.
It will operate up/down/in/out on the lever but that’s it.
Do I need to switch it on somewhere? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529629 30th Sep 2019 9:52pm
Its settable in the dash menu, i think its easy entry/exit Thumbs Up
Post #529636 30th Sep 2019 10:47pm
Andy
I don’t recall seeing that setting but I’ll have another look in the morning. Thanks Craig. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529637 30th Sep 2019 10:52pm
Post #529638 30th Sep 2019 10:59pm
Andy
I’ve just had a look and the easy entry/exit is ticked. Must be something else stopping this working then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529646 1st Oct 2019 7:38am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hi Andy, what position is your steering wheel set to? On mine I have the steering wheel set as high as it can go so there is no more movement available for the entry\exit option. If I lower it then the wheel will move as it should. Might be worth also unticking the option in the menu, switch off ignition, give it a few seconds then switch back on and retick the option. Sounds an odd thing to do but it’s computer controlled and like all computers they sometimes forget what settings have been selected
Post #529659 1st Oct 2019 9:44am
Andy
I’ve always had it to the highest position.
I’ve just adjusted it to a lower position and tried it again. The steering wheel does go back up to the high point but doesn’t retract in. I can’t see any movement in the seat either. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529680 1st Oct 2019 12:39pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Seat memory ecu might be gone. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #529690 1st Oct 2019 1:47pm
Andy
Seat ECU seems fine. All the memory functions still work? No faults logged with IID 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529694 1st Oct 2019 1:55pm
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Are they supposed to retract?? Mine just raises to the highest position which I thought was normal.
Post #529704 1st Oct 2019 3:55pm
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Could be a Motor fault on the Steering Column. Had to change one on my last L322 due to the Ignition Key not turning. Got a Second Hand one but when i fitted it the Up and down wouldn't work so took the Motor off the Old one and swapped it out.
All good after that Cool
Post #529787 2nd Oct 2019 9:05am
if it al works manually on the lever then the key isnt telling the ecu to do its bit ..
have you tried the spare key to see if that one does the job.. ... - .- -.
Post #529788 2nd Oct 2019 9:12am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I really must 'STOP' reading sensible advice on forums!
I tried the spare key in order to leave it in the car for use on the garage lifts.
Big mistake. Big Cry
I get into the car as normal. (heck it is my car thus everything is where it should be).
and I instinctively apply the seat belt.
Put unused by me 'spare ignition key' in.
Now the we have the complete FF-Anti-Villain mode.
With the seat belt fastened and the previously unused spare key in, the seat starts to move forward and down, the steering wheel is coming towards me and also heading down.
The lap belt part is getting tighter and tighter, and still the steering wheel is moving inexorably towards me.
Breathing could become an issue, the shoulder strap part is now also trying to strangle me.
Finally all movement stops and I'm almost 'immobilized' but my right arm still seems to be sending signals to my hand.
I manage to stretch down and with a last effort hit the "#1 seat memory button".
DEEP JOY
The computer kicks in and the seat starts to move away, the steering wheel moves inwards and upwards, blood starts to recirculate in my 'nether regions', breathing is now a possibility, and "Normality has been Restored"
The morale is, do not use the spare key unless you are sure that a 7 year old did not program it to the car!
Best Rich
Post #529976 3rd Oct 2019 9:05pm
Laughing
done the same when i pressed the seat memory on a new FF purchase.. ... - .- -.
Post #529984 3rd Oct 2019 9:48pm
