Home > Technical (L322) > Do I remove the map to cure the faults? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
So my restricted performance woes continue.
23rd Sep 2019 9:11am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
i'd check them hoses!!....
23rd Sep 2019 10:13am |
I have. I use the IID tool. Same code every time - PO23D map sensor/ turbocharger boost sensor 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
23rd Sep 2019 10:17am |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 198 |
Have you checked the map sensor to see if it’s clogged up ? And as Stan says check your inter cooler hoses Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
23rd Sep 2019 10:25am |
Hoses were fine but I replaced them with silicone when I found out about the remap.
23rd Sep 2019 11:56am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
"what if the map isn’t at fault and I lose the remap? I’m not sure who’s map it is as it was on the car when I bought it and the chap I bought if from said he hadn’t done it."
26th Sep 2019 7:19pm |
if its on one bank rather than the other, then it will be something specific to that bank, have a search for the plastic inlet manifold cracks, which are not unknown on the 3.6.
26th Sep 2019 7:48pm |
I’ve checked the manifolds. I’ve sprayed them with soapy water whilst hot and I’ve also done a smoke test on it.
26th Sep 2019 8:12pm |
So coming back to removing the map.
1st Oct 2019 3:21pm |
I doubt anyone can give you an answer to that, there are so many variables, what was the map intended to do? who did it? how well was it done? what other issues could the engine have? etc.
1st Oct 2019 4:17pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 659 |
Have you thought about remapping the map?
1st Oct 2019 5:39pm |
