![]() | Home > Technical (L322) > What's this ticking noise??? |
| Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51
hmmm, what's this ticking noise?
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
Left side when sitting in the car? Sure it wasn't the FBH? 2016 Skoda Octavia VRS Estate
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
+1 fbh... ... - .- -.
Thanks guys, I would be more certain if I knew what an "FBH" was? 2010 TDV8 3.6 Vogue Stornoway Grey |
AHA! Fuel Burning Heater! it WAS a cold morning and it went tic tac tic tac around 5 times then stopped, does this sound typical? FFRR
It should run when 6 degrees or below (IIRC). It makes a few ticking noises and then starts to more of a whine but you wouldn't normally hear the whine over the noise of the engine. You will also likely see some smoke if you look in the wheelarch on the LHS when it starts up. You can usually hear it winding down as well as it goes through a shutdown procedure when the engine is turned off. More info in the Wiki. 2016 Skoda Octavia VRS Estate
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
If you've got the FBH, then you could try using the park heating to warm the car interior up prior to getting in when the temperature outside is below 16C.
I said 6 degrees above but I think I'm getting confused with my old D3. I was under the car today and the FBH was running and it was a lot warmer than 6! 2016 Skoda Octavia VRS Estate
Mike
| All times are GMT |
