Home > Maintenance & Mods (L322) > IID Tool Tips required
Hozza12163
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I have changed some simple bits but some others don't seem to work, if you have modded these yourself I would be grateful for a pointer in the right direction if you have a moment?
Switch on Digital speedo - working
enable angel eye DRL lamps on with engine - working
enable cornering lamps - not working (do I even have them? How would I tell? I have 2010 facelift Vogue 3.6 TDV8)
enable single press superlocking (I think this is working)
enable chirp on locking - not working - it chirps twice on unlocking instead which used to be reserved for when you left a door open
my mirrors now only fold in if I lock and unlock then lock again - before they used to fold every time
Adaptive headlamps - they move when I switch on the car but the don't move when I turn the steering (they may not be adaptive - how do I tell?)
if anyone has tips to cure these issues, please holler FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #529991 3rd Oct 2019 10:39pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I had the mirror situation when i tried to enable the chirp on my L405 . I had to go back to original settings to resolve the issue. Just my experience sir Thumbs Up Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #530007 4th Oct 2019 7:25am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Cornering lamps are a factory option, not fitted to every car.
Post #530009 4th Oct 2019 7:37am
Hozza12163
Thanks, how do I tell if I have them? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530054 4th Oct 2019 6:22pm
Hozza12163
found a tip for this which works - sit in the car and wind the mirrors in on the button, get out the car and lock it, unlock it again and they should wind out. This should remedy the issue
Mine are now working again! FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530055 4th Oct 2019 6:31pm
Mr Tee
Looked at an old photo and I think there should be 3 slashes and a visible bulb bellow the indicator, if yours had them , you would definitely notice at night time Thumbs Up
Post #530059 4th Oct 2019 7:20pm
Hozza12163
I can't see a bulb in there, is it simply a matter of shoving one in and enabling it in the IID tool, can't imagine there would be separate looms and controllers for each model? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530100 5th Oct 2019 4:19pm
Mr Tee
No idea mate, Craig would be the man to ask.
Post #530101 5th Oct 2019 4:22pm
