Home > Technical (L322) > leaking wiper motor, suggestions?
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
As above, my rear wiper motor is leaking. Looked it up in the wiki but no solution. It works well, it does spray the rear window, but it leaks in the arrowed spots . I've opened it up, cleaned it out, found no obstructions...Any suggestions would be very welcome. Thanks
Post #530044 4th Oct 2019 4:55pm
Might be time for a new one..... this thread may have some suggestions
Post #530045 4th Oct 2019 4:58pm
Robert
Thanks Alistair, I did read those 6 pages Wink
Post #530049 4th Oct 2019 5:04pm
Biffa4444
I had a similar problem, mine was seized so stripped and fitted a new gear wheel and cleaned out all the gunk.
Worked lovely but leaked as you describe. Found that where the spindle goes through the cover there's a rubber seal and it wears a groove in the shaft after a while. So I took mine apart, cleaned the seal then wrapped a couple of turns of electrical tape around the shaft and smeared with silicon grease. I had to stick the seal housing back with ct1 but so far so good, its working fine and not leaking
Post #530203 6th Oct 2019 10:40pm
Robert
Thank you, Thumbs Up will try to open up once again today
Post #530220 7th Oct 2019 7:37am
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
Hello Robert ,
when I open it , I become a other idea
no more water inside the gearbox, I have a seperat tube for the water on the rigt side from the wisherengine
and on the wisher are the water jets , now comes more water on the glass
Post #530248 7th Oct 2019 2:40pm
Robert
good Idea Frank, thanks, I'll have a look into that, see if that's feasible on mine Thumbs Up Thumbs Up
Post #530251 7th Oct 2019 4:46pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
good idea Thumbs Up Thumbs Up
Post #530253 7th Oct 2019 4:58pm
FrankN
Thank you all Razz , Robert it gives only one place where you can drill for the tube , look at my picture and you must a plastik cover around the tube , it’s white on my picture .
Post #530254 7th Oct 2019 5:04pm
Robert
Yes, I've seen it and looked on mine and think I found a drilling spot. What kind of wiper is that on yours?
My Corvette has got the same system, but the wipers are totally different.
Post #530259 7th Oct 2019 6:22pm
FrankN
The wiper is original, the jets are from a truck Laughing
Post #530261 7th Oct 2019 6:45pm
Robert
creative!! Laughing Thumbs Up
Post #530263 7th Oct 2019 7:12pm
