Home > Technical (L322) > Rear suspension
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
Rear suspension
Gentlemen the fatty has gone back to 70s and jacked up it’s suspension,
I picked up a load of tiles then got the air suspension inactive warning
and now this , any ideas TIA Mark
 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #530102 5th Oct 2019 4:25pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Assuming that you have now removed the tiles Whistle
Have you tried all the usual things like, raising & lowering with the doors shut, Driving over 40 mph etc.
Sounds like it still thinks that the weight's still there. May have to do a hard reset. Thumbs Up
Post #530107 5th Oct 2019 5:26pm
looks like its stuck in off road height, have a look in the wiki for the solution.. ... - .- -.
Post #530108 5th Oct 2019 5:29pm
markyp
[quote="Highroller"]Assuming that you have now removed the tiles Whistle
Sounds like it still thinks that the weight's still there. May have to do a hard reset. Thumbs Up[/quote
Yep tried all that, forgot to mention there are no lights on the panel where there should be for the control to raise and lower the suspension 2004 vogue
2010 Fiesta
Post #530118 5th Oct 2019 7:33pm
markyp
Will take a look , Thanks 2004 vogue
2010 Fiesta
Post #530119 5th Oct 2019 7:34pm
No lights, hard fault, requires reset with diagnostic tool
Check fault codes first though, could be a height sensor issue.... .
Post #530120 5th Oct 2019 7:44pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Looking at the pictures.
The outside edge of the tyre and the state of the alloy wheel suggest that you will have worn suspension parts/bushes AND stuck brake calipers.
Maybe a wagon load of tiles was a 'bush's' last straw?
I am in the process of replacing the whole of the rear suspension on my 2007 as we speak.
Best of luck, Rich
Post #530121 5th Oct 2019 7:51pm
markyp
So the car was looked at today, plugged in to the diagnostic tool which obviously showed a fault , Hit the reset button and hey presto all is good, I reckon my mistake was not starting the car while I was loading the tiles so the suspension could self level, Thanks for the advice Gentlemen. 2004 vogue
2010 Fiesta
Post #530352 9th Oct 2019 12:02am
