![]() | Home > Technical (L322) > Ten years with no trouble. Now possible Gearbox problem ? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
You may wish to try a gearbox flush rather than just an filter change.
Blubberman Member Since: 11 Nov 2010 Location: South Wales Posts: 39 ![]() ![]() ![]() |
Thanks for the suggestion, any help much appreciated.I will be taking it to my local RR specialist this week . Hopefully something simple . Its big , its black and we call it THE BEAST ! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Might be a solenoid on the way out
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I would definately do a full flush and new filter first. When I fisrt got my fatty i just did a filter change and top up. It took 4.5 litres to fill and thought that the old oil coming out was fairly clean. A year later and the gear change was clunky so I did a full flush. The old oil was very dark and dirty. Not black but not good either. It did the job and sorted the clunky shifting.
Just spoke to my local indy, they say that the symptoms are unusual , so its going in this week for an evaluation. Time to dust off the credit card again |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
10 years with no trouble. Think this should be a sticky lol. |
Yes , ‘tis true , but then I try to stay on top of the preventative maintenance and not wait for things to fail. Generally the strategy works ok, except this time I did bury my head in the sand and convince myself it was my imagination |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Losing drive when setting off from junctions rings a bell. On mine it also started happening whilst driving along.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
What I would be concerned about is the fluid change. The gear selector pivot has it's possibility too. If your lines rusted through how do you know rust or water hasn't contaminated the fluid? There are concerns about doing the total flush. Theoretically it can dislodge crud and get caught in small passages. One would assume if it is done right it will blow all of it out. I've done one filter and fluid change at 119k, 2 just drain and fills up to 165k with semi synthetic and now a drain and fill with pentosin. Have a filter waiting but I tore the gasket. Got better after every change. Very smooth now. |
Thank for the suggestions guys, it is all Grist to the Mill .
Update on the gearbox fault.
Can you not do the drain and filter yourself? It's not hard. I've gotten Febi brand fluid for as little as $8 US a litre. Pentosin for $10. Goiter and gaskets are cheap. $450 US is just an outrageous price for what can be done for about a tenth of that. |
Yes, I can, and I have indeed changed both the oil and filter in the past , but to fully flush the system it will take a lot of oil but I really don’t think an oil change will fix the gearbox on this occasion Its big , its black and we call it THE BEAST ! |
You may be right but even if you do just a drain and fill without a new filter, drive it a bit, you may see a change to give you an idea if this is right path. |
