Home > Maintenance & Mods (L405) > Fuse 63 replacement - How! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
not sure what access is but maybe use a pair of long nose pliers? ... - .- -.
9th Oct 2019 4:10pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 355 |
Hi Stan, the access hole is small and number 63 is located between a relay and a large strap connector so it's slightly buried by the surrounding items. Not sure I could get pliers to get a grip the fuse. 2019 L405 SDV8 Autobiography
9th Oct 2019 4:20pm |
must be a 'fidlle' job then, unless someone else knows how .. ... - .- -.
9th Oct 2019 4:33pm |
are you sure its number 63 and is in fact a fuse? could it be a permanent fuse of some kind?
9th Oct 2019 4:38pm |
Mine's a 2013 and doesn't have the front glovebox power socket that the later models have.
9th Oct 2019 4:45pm |
i dont have one in the glovebox either [2016] but i do have one next to the cup holders like yours,
9th Oct 2019 5:10pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 338 |
You can do it with the fuse puller that is clipped to the fuse board, it's bloody fiddly but can be done, I did mine yesterday.
9th Oct 2019 5:18pm |
Definitely number 63 in my manual.
9th Oct 2019 6:04pm |
Fuse 63 sits below the red 10 amp fuse shown on the bottom (middle) the photo below
9th Oct 2019 6:22pm |
It's 100% fuse 63 on a 2013 and if you are struggling to swap it, that confims it even more. Current
9th Oct 2019 6:24pm |
Just ordered some of these. Hopefully they should assist🤞
9th Oct 2019 6:41pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
holy moly - they look like some medieval torture instrument ! |
11th Oct 2019 12:05pm |
The pliers have just been delivered but unfortunately the ends don't close enough to grab the fuse.
11th Oct 2019 12:12pm |
this is starting to cost a bit now ... - .- -.
11th Oct 2019 12:15pm |
