![]() | Home > Technical (L322) > Can water leaks cause battery drains? |
jameshill Member Since: 15 Jul 2019 Location: Manchester Posts: 20 ![]() ![]() ![]() |
Wow, L322s are a full-time hobby to keep running aren't they!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8107 ![]() ![]() ![]() |
I guess if water is causing something to remain on, then it would indirectly drain the battery.....
Nice, thanks for sharing that thread. Will definitely give that a try for the sunroof drain. |
Ok, thanks, will probably try to fix these leaks, dry the car out and then revisit the battery drain.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
For fuse 49 the two things I would be looking at closely, by taking the cases off, would be the satnav unit and the dsp in the back left compartment. Are you sure the upper tailgate rubber seal is ok? |
That was a fun evening.
Think I’ve fixed the leaks!
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
I had the dreaded battery drain in my 04 4.4 - eventually traced it to the little fan in the hevac panel that never powered down. Re-wiring it so that the whole thing powered off with ignition off finally sorted it. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Ah really, thanks for the heads up. How did you track it down exactly, to the fan itself?
Might help you in your quest:
Awesome, thanks so much, will have a read.
Hi all,
You should also start the car, let it run for a little bit to settle down, have most things turned off, e.g. lights/AC, and check the voltage across the battery terminals - (this will tell you what the alternator is kicking out)
Thanks Joe!
