Home > In Car Electronics (L405) > What happened to spotify?
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
It was there in the incontrol app and then it vanished. I reinstalled incontrol, it was there again for a moment, then deleted itself. Did they remove it from the app? If so pretty frustrating because I used it quite a bit.
Post #530458 10th Oct 2019 4:17am
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
apparently it has been removed from incontrol apps. Only way to access is via apple car play. No idea why they stopped the licence! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #530511 10th Oct 2019 5:52pm
brad s1
Can carplay be put on the old nav where the buttons are arranged physically on either side of the screen vs virtually on the bottom. TIA
Post #530521 10th Oct 2019 8:22pm
Mark1107
United States 2013 Range Rover HSE 5.0 V8 Fuji White
Brad:
Www.androidaftershock.com
Post #530538 11th Oct 2019 2:51am
gibbo37
United Kingdom 2016 Range Rover Autobiography SDV8 Waitomo Grey
Have you seen this?
https://news.theceomagazine.com/technology...rplay/amp/
Actually I think this might be for the newer full screen versions only, it was the reference to 2016 models that confused me!!
Post #530539 11th Oct 2019 7:12am
refers to Australian owners so msybe not here in the UK?. ... - .- -.
Post #530543 11th Oct 2019 8:01am
brad s1
I saw a similar article... how do you know if you have InControl Touch Pro vs just in control touch? I have a 2016 which is listed as eligible for the update but says it requires the pro version. Mine has the smaller screen with the physical buttons on either side does that denote just the standard version?
thanks
Post #530640 12th Oct 2019 2:31am
