Home > In Car Electronics (L322) > Harmon Kardon Logic 7HD
Page 2 of 3 <123>
mjdronfield
I did.....then turned it back off. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #515035 11th May 2019 11:38pm
Bryanrambles
I also had a play about but couldn't get satisfied.
I opened up the rear compartment and confirmed the subwoofer is working, sounded better when compartment door was off.
Post #515068 12th May 2019 11:21am
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
My 2012 Westminster has exactly the same fault with the SW and Bass, it has been in the dealers on numerous occassions and has had all the relevant components changed including the amp and speakers. Their "master" technician eventually said that they weren't very good in my model and he recommended getting an after sale solution..I had all the software updated but still the same, got bored with complaining so now put up with it...I have also tried various inputs but no joy......sorry I need more help than most...sorry !!
Post #515134 12th May 2019 9:30pm
GGDR
I love my HD system. No complaints.
I've only have Bose speakers in my home(s) for many years so I enjoy a good sound system.
But I've never heard such a good sound system in a vehicle as this HK HD.
I like mine so much, I think I blew my sub.
I saw they are not too expensive and it's on "the list"
Am getting by at the mo with a low sub setting.
. Cheers, Greg
Post #515138 12th May 2019 9:52pm
ikjos
Norway 2012 Range Rover Westminster 4.4 V8 Santorini Black
Bumping this thread.
I've just bought a Westminster and I'm really not impressed with the sound system. My bluetooth speaker play much better/louder... I've tried to adjust everything. I don't have the IID tool so I can't check for any faults.
It's OK for the short commute to work and back listening to some random radio but sometimes I really want to oomph it up but that's not possible. Won't impress anyone with it.
Just sharing my small frustration since I thought it would kick a bit more.
I'll probably bring my bluetooth speaker with me in the trunk for those long trips Cool
Post #530514 10th Oct 2019 7:13pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Mine has the HK system in it and you can get colossal volume out of it with very firm gut wrenching Bass notes. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #530519 10th Oct 2019 7:36pm
mjdronfield
Try turning the Logic 7 off. It’s loads better. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #530522 10th Oct 2019 8:40pm
ikjos
I've tried that too with the only result that everything sounds more "flat" and definitely not more punch to it.
Post #530526 10th Oct 2019 9:22pm
Hozza12163
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Just tried my 2010 Logik 7 on and off and tbf I think it's better with it off. More punchy bass and crisper all over, Logic 7 on is definitely wider but less punchy. It's a subtle difference FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #530623 11th Oct 2019 8:50pm
GGDR
ikjos sounds like an amp issue to me.
Have you got an IIDTool? Or another fault code reader?
. Cheers, Greg
Post #530626 11th Oct 2019 9:26pm
ikjos
No, I don't have the IIDTool (yet). And yes it's probably the amp. Does any of you have experience with those? Just to throw away and find a replacement? Any after market ones that would fit?
Post #530677 12th Oct 2019 5:13pm
WdeRave
Spain 2010 Range Rover Vogue TDV8 Santorini Black
My Range has the Logic7 HD and the sound is amazing. Have some R&B and you expect the roof to be blown away.
Added a small Bluetooth device connected to the aux in the back, hidden in the armrest and solved the "connectivity" issue.
Also updated the DAB to DAB+ (module swap)
 RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
(EGR out, 380HP, 800Nm)
Post #545918 3rd Mar 2020 9:58pm
dazza1983
Why add Bluetooth when you can just connect a iPod?
Would like to know more info on dab + upgrade please Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #545924 3rd Mar 2020 11:12pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Or with the Bovee have full access to your playlists etc without having to handle you phone nor plug anything in.
Post #545926 3rd Mar 2020 11:23pm
WdeRave
Sorry guys, Android over iOS .... Whistle
Mail form Feb 2019:
If your 2010 L322 Vogue already has DAB, and you want to upgrade to DAB+, this is not too complicated.
I can supply a DAB+ module with the mounting bracket so it fits exactly where the original DAB module was located, also some adaptor cables for the power and antenna, so you do not need to cut or solder anything, it's just a matter of unbolting the old module, bolt in the new one, and plug in the cables. No programming needed.
There is a bit of work involved in accessing the DAB module, I have attached the instructions from the workshop manual so you can see what is involved.
For an "upgrade kit" it would be $810 AUD (~520 EUR) plus postage to Belgium, I guess around $50 AUD (~33 EUR) for postage with tracking.
I have all the parts here on the shelf will just need a day or so to prepare the kit.
Regards,
Cameron
+61 488 121 890
cambo@oldjaguar.com
www.facebook.com/oldjaguarau
www.oldjaguar.com
Post #545928 3rd Mar 2020 11:32pm
Page 2 of 3 <123>
