Home > Maintenance & Mods (L322) > wheel arch rubber seal
Page 2 of 3 <123>
pld118
Agreed Welshdragon... £5.98 delivered for 2 x 2 metre lengths of the protective plastic strips plus £5.99 for the Comma grease.
Already had the Tardis and Iron X so thanks to the forum (again!) for under £12, 2.5 hours of my time and my old T shirt getting ruined with grease, it feels like a simple but proper job well done, knowing that when the car is washed over the months and years to come, rusted rear arch paint won't be flaking off onto 'the sponge'!
Post #264284 9th Jun 2014 9:44pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I intend to do this and sort the small rust bubbles in the rear door area. Hope to get it all done in a month or so.
Great tips guys Thumbs Up
Post #264293 9th Jun 2014 10:06pm
If your Rangie is getting a bit old, take off the sill trims, push fit fittings underneath and then just pull it hard to release the numerous clips, and have a look at the rear of the sills.... If you need to remove the jacking points, prise out the plastic peg in the middle and they pull off
My 2002 looked like this, taken a while to get that bad and would be any easy fix if found a few years ago...
 Pete
Post #264342 10th Jun 2014 7:26am
Don't know why the pic is upside down, definitely wasn't standing on my head!!! Pete
Post #264343 10th Jun 2014 7:27am
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Just ordered my rubber strips!!
Post #264441 10th Jun 2014 2:42pm
pld118
Daft question.
Now that the inner arches/ flanges are or should be caked full of grease, when washing the car, do
I still train a spray hose in those areas under the arches or do I not bother for fear of spraying out all of the grease that is in situ to try and prevent corrosion?
Thanks Thumbs Up
Post #265660 16th Jun 2014 9:56am
mjdronfield
I've left mine with vasalene in and just check it every so often. I don't spray water at it.
Others may do differently of course.......but as you say, prob wash the grease out...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #265766 16th Jun 2014 7:53pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Just done my arches using the strip recommended by NiceDayForIt (thanks for the tip)
I also filled inside the strip with grease before attaching to the car.
Used a small syringe to inject the grease and worked very well.
I found after initially attempting to load the syringe from the top with plunger out, that it could managed to suck the grease in to load itself from the spout end which saved time
 Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #288631 24th Oct 2014 2:59pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Dragging up an old thread, but having had my ever ever ever so slightly rusty arches sorted yesterday, I've also bought the plastic strip. My rather daft question is, the original strip on the rear of the arch is coming away, however the arch itself is fine. Am I best just to replace it with the new plastic ones or try and get something to stick it back down?
See, I did say a daft question. Embarassed
Post #396222 15th Jul 2016 3:30pm
pld118
Replace with new plastic ones Thumbs Up
Post #396229 15th Jul 2016 4:05pm
archermav
lovely, will sort it tomorrow (if it ever stops raining).
Cheers Thumbs Up
Post #396230 15th Jul 2016 4:07pm
DrRob
nicedayforit wrote:
I've used the door edge protector shown below on the wheel arch return flange.
Had it on a couple of years up to now.
Before fitting I cleaned the flange on both faces and applied a liberal coating of black grease to each face, fitted the protector strip and cleaned off the excess grease.
Just took the strips off recently to clean, regrease and refit. The flanges are like new.
Done my daughters Freelander the same way instead of using the LR replacement part.
IMO the plastic strip is better than the LR strips as it is all plastic and therefore doesn't corrode.
Looks very professional when fitted.
http://www.ebay.co.uk/itm/Car-Door-Guard-E...27cac56ea1
Could you please post a picture of these in place? I would like to compare the appearance to the LR strips. Thumbs Up Thanks in advance Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530770 13th Oct 2019 5:25pm
GGDR
I really wanted one continuous strip front to back so I bought something similar to the ebay link in rubber.
Problem was if you run it around the lip when you get to the at the 12 o'clock position there is a kink in the lip and I could not get the rubber edge to conform.
So never fitted it. On the 'to do list' though.
If you could fit a plastic something that could be heated to adapt to the kink it would be an ideal solution
How did others deal with the kink?
. Cheers, Greg
Post #530780 13th Oct 2019 6:54pm
If it ever stops raining I will take a picture and post tomorrow for those interested. Thumbs Up
Post #530793 13th Oct 2019 8:34pm
As requested.
Front edge of wheel arch
Looking up at rear of wheel arch
Sorry about the second photo, it's almost impossible to show the strip clearly against the black wheel arch liner.
Post #530880 14th Oct 2019 8:02pm
Page 2 of 3 <123>
