Home > Technical (L322) > 3.6 TDV8 running rough
LeonL322
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
hi my car has started to run rough and knock no fault codes or lights present however the offset on injector 6 is maxing out at 1.4k I have a injector coming on Monday (tomorrow) however the only think that worrying me is the crank case pressure, i have read a story where a egr valve head comes away and enters the engine, is this common or am I just worrying for no reason.
Cheers
Leon
Post #530784 13th Oct 2019 7:16pm
LeonL322
UPDATE
Ive taken the car to the garage they found cylinder 6 injector maxing out with a offset reading, they removed the injector and found it to be 'wet', so i had them change the injector however the fault still was still present. They then done a electronic compression test and found that a cylinder is only making 1% compression. has anyone had a similar experience with their 3.6??
it seems like a serious failure has occurred with nothing but expensive things left such as piston, valves, cam/rockers and head/and or gasket
Post #531265 17th Oct 2019 6:04pm
the most comon problem on the 3.6 are the turbo hoses..have you checked those ? ... - .- -.
Post #531267 17th Oct 2019 6:30pm
LeonL322
It’s had a new turbo and hoses recently
Post #531369 18th Oct 2019 10:38pm
