Home > Maintenance & Mods (L322) > Servicing Costs and/or any Recommendations?
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
My '56 plate TD6 is coming up for an Inspection 2 service and my preference is to use a main dealer because the year's LR warranty is about to run out and I'd hope to get any problems they may find taken care of under that (bar usual run-of-the-mill stuff - I expect I'll need brake pads/discs sorting). Having said that, I've no reason to think there's anything wrong - it's been fine during the last 12 months.
Local main dealer wants around £530 for this (I forget the exact figure) and even a local independent is still around £450. Seems a lot for an oil change and a couple of filters, but I appreciate that the car will also be hooked up and checked over for anything else (that they can charge me for!).
Anyone out there with any suggestions for good servicing/costs in the Reading area?
Thanks.
Post #53080 5th Mar 2011 7:51pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Scarey is from your neck of the woods. I expect he'll have some info for you. Both sound expensive to me. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #53081 5th Mar 2011 7:56pm
i'm no where near berks ,greg. Laughing
can help i afraid , my eldest does all my stuff.... ... - .- -.
Post #53102 5th Mar 2011 8:56pm
dan_uk_1984
Anything from the dealer will be expensive. If you want the stamp for your warranty and continuity then you have no choice.
However if you want to save money they any garage can change your oil and filters for you. I would suggest changing the air and pollen filter yourself (it turns out LR dealers often don't bother with these!)
I'd expect to pay no more than £100 for an oil and filter change, inc parts. Mine has just cost me about £60 inc parts & labour.
Post #53111 5th Mar 2011 10:36pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
No where near you so can't help with that bit but I recently had an inspection 2 with my Landrover specialist (but not main agent). It was £360 and he did a coupl eof extra mods with his autologic for me that I asked for (enabling TV in motion and cleaning the rear wash jet)
I would say £460 from an indy is a tad expensive. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #53112 5th Mar 2011 10:39pm
GregP
I thought you were close to reading?? Confused FFRR TD6 HSE
Post #53125 6th Mar 2011 12:24am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Main agents often offer lower priced services using Landrover approved parts.. but if you don't ask they are unlikely to say so. I recall my last was much much cheaper and I still have a main agent stamp. Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #53126 6th Mar 2011 12:48am
about 40 miles away.. ... - .- -.
Post #53137 6th Mar 2011 9:48am
GregP
See, that's a stone throw away Smile FFRR TD6 HSE
Post #53139 6th Mar 2011 10:33am
but i live in a glass house so i cant throw stones... Wink
off topic...... Very Happy
back to the question, if your preference is to use main dealers then you pay the price for that.......
btw , i saw a mattabooboo yesterday... ... - .- -.
Post #53140 6th Mar 2011 10:53am
bogie
£199 Inspection 1 or £299 inspection 2 around here at indy
dealer is £500 or £700 for same ...mostly down to labour rate, parts prices not much different
£150 an hour labour for a £15 an hour mechanic leaves a lot of big overheads, but then you get a coffee and dolly bird to bring it to you ...at the indy you just get to talk to a LR bloke cheers
bogie
Post #53142 6th Mar 2011 11:20am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Re: Servicing Costs and/or any Recommendations?
Thanks.
Not quite Reading, but if you want to go to Didcot/ Abingdon, Frogs Island 4 x 4 are very good and very reasonable!
http://www.frogsisland4x4.com/index.php?op...;Itemid=58 Thumbs Up 2012 SDV8 Vogue SE
Post #53143 6th Mar 2011 11:23am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Guava at Guildford may be closer to Reading, I don't know what they charge but they have a very good name on RRSport and Disco3 for those living under the flight paths into Heathrow. I'm not sure (judging by the website) if they are even strictly Independents
http://www.guavaguildford.co.uk/ 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #53144 6th Mar 2011 11:45am
T24RES
There is an Indy at Portman Road Industrial Estate. I shall grab the name on my way past today and post up later.
* Couldn't see it, perhaps they've gone bust/moved Ian
Post #53159 6th Mar 2011 1:55pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
'Sigh' Go on then Scarey, whats a mattabooboo
(Couldn't leave you hanging like that Laughing ) My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #53198 6th Mar 2011 6:56pm
