Home > Technical (L405) > Jacking the L405 with side steps
Page 2 of 3 <123>
jackcramerr wrote:
I'll see if a magnet sticks to it as when I touched it, knocked it, it didn't feel like metal.
I reckon you'll be safe enough taking my word for it! i must have lifted upwards of 400 RR's on my 2 poster ramp... More than half have had steps fitted... Whistle
Post #530807 14th Oct 2019 1:30am
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
can confirm that is a good jacking point just make sure you shut the steps off first. Apparently the car can sense it's at some weird articulation and disables the system, tho I just assume not risk it.
Post #530925 15th Oct 2019 4:37am
jackcramerr wrote:
How will trolley jack be able to work/hold the curved surface? Notice the factory jack has a slot/grove.
My trolley jack has a circular plate which covers the area marked in yellow & lifts it just fine.
The jacking point being that bit lower actually makes it easier to lift a car with deployable steps than without.
The standard equipment jack that comes with the car is well documented as being Censored and I'd only use it if I absolutely had to.
Post #530938 15th Oct 2019 7:57am
jackcramerr
So the SGS 2.5 ton trolley jack I have has a rubber pad. No slot for grip.
Is your trolley jack different?
Post #530952 15th Oct 2019 10:16am
I have exactly the same jack - works fine with the deployable steps Thumbs Up
Not sure whether it would have the reach required without the step jacking point being lower.....
Post #530953 15th Oct 2019 10:33am
brad s1
IMO throwing a bit of hardwood 2x4 between the jack and the car is better than just jacking on the puck, more stable/height increase/mitigates scratches/damage/disperses the load more evenly.
Post #530999 15th Oct 2019 4:35pm
Well I guess some wood if you're worried about the height Whistle
Post #531007 15th Oct 2019 4:59pm
jackcramerr
Post #531531 20th Oct 2019 12:52pm
The system shuts off with the terrain response sir... If you have it set to AUTO as most of us do, as soon as it senses a potential issue I.E. it thinks your driving in muddy ruts. It shuts off the steps so it doesn't damage them trying to deploy them against a bank... Thumbs Up
Post #531555 20th Oct 2019 5:51pm
jackcramerr
The steps are made from plastic. And trolley jack does foul it and cuts off bits of plastic. So be warned.
Post #531637 21st Oct 2019 1:26pm
If yours are made of plastic then they are non genuine! Probably Chinese I would guess? JLR step brackets are cast metal of some description! Certainly not plastic sir...
Surely they would snap off with a 240lb man stood on them?
Strange Neutral
Post #531666 21st Oct 2019 3:53pm
plastic tops and side trims ???? ... - .- -.
Post #531668 21st Oct 2019 3:58pm
I'm trying to figure it out from the photo, but they look different to mine - this is a side view -
Post #531670 21st Oct 2019 4:04pm
heres a rotated pic for comparison,
could it be the rear end?? ... - .- -.
Post #531672 21st Oct 2019 4:13pm
The step itself looks different
Post #531681 21st Oct 2019 4:28pm
Page 2 of 3 <123>
