Home > Maintenance & Mods (L322) > EGR Cooler Complete Removal?
Fish13
Hi all,
2003 TD6 - I’ve already done the EGR blanking kit, but have now got a slow coolant leak from the EGR cooler.
Am I right in saying I can remove the cooler and thermostat unit, and just blank the two hoses with plugs?
Has anyone done this and can you recommend a plug kit? There seems to be lots for the BMW models but not sure which one would suit the Rangie?
Many thanks in advance!
Fish.
Post #530647 12th Oct 2019 9:36am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Yes, it is well documented as a success. Off the top of my head, you need 2x 15mm caps for the hoses and a blank for the exhaust. A full in-depth write up is in this forum, try a search 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #530658 12th Oct 2019 12:07pm
Fish13
Many thanks - I could find a lot on the basic blanking kits, but not much on the actual removal of the cooler and the thermostat.
Cheers,
Fish.
Post #530672 12th Oct 2019 4:32pm
wayneg
This kit although more expensive than most appears to have custom parts to blank the water hoses along with the exhaust... Not right for our engine but the diagrams show the water pipes that need blanking https://www.ebay.co.uk/itm/BMW-3-SERIES-E9...SwaadayKRu 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #530707 13th Oct 2019 1:07am
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
I removed the EGR, EGR Cooler, and viscous fan/shroud from my 2003 TD6 and the car seems much better now.
https://www.fullfatrr.com/forum/topic51131.html
Post #530964 15th Oct 2019 12:15pm
