![]() | Home > Maintenance & Mods (L405) > P040D-00 (2F) Exhaust gas recirculation temperature sensor A |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
Does anyone know which sensor this relates to?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic48131.html
Will it be the same though as that topic is for TDV8, mine is a SDV8? Current
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Andy, essentially the same engine -- so we believe it to be the same issue.
Virtually the same car |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
Just had a little play and Bank 2 sensor 2 is at a constant 0V all the other EGT sensors fluctuate.
Less flippant reply |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
A few of us have that error with no obvious issues but if they will replace it for free then |
It's on a warrantywise warranty and they've tried once but done the wrong sensor |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
it's not documented and it flummoxed me and a few of us for a while, not the first time I've read a dealer replaced the wrong one - this led to dealers proliferating the story that it's a ghost code / that all do that sir. If you haven't read my guide it's on the NS exhaust manifold. Once they find the correct location, the job can still go wrong without repeated WD40 soakings (the nut can round off)or in Craig's case they didn't clean the thread out properly before fitting the new one (false torqued nut). Get it wrong and the manifold's got to come out which is not pretty. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
