![]() | Home > Technical (L322) > New compressor suspension won’t drop |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6421 ![]() ![]() |
You mean it will not come down from Off Road height using the dash buttons ?
S700TNG Member Since: 25 Mar 2019 Location: Tamworth Posts: 6 ![]() ![]() ![]() |
It Won’t go from normal to Access
Try battery disconnection procedure (to clear ECU and unconfuse EAS ECU)
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
I think Joe90 is right , I assume the old comp was goosed ? so its probably got old codes stored up from trying to achieve demands which the old comp couldn't meet ? |
This is the only think that’s coming up still won’t drop the front
Did you try the battery disconnection procedure ? .
Yes |
Suggest check all your air bags and sensors, then do a calibration .
Starting to think height sensors are stiff |
Is there an Exhaust for the front suspension was it just one central exhaust delete all down |
There is a distribution valve at the front (front RHS wheelarch), at the back (rear RHS wheelarch) and on the reservoir .
