![]() | Home > Maintenance & Mods (L322) > Advice on egr fault |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I had this one for a long time with no symptoms but cured it as found the plug under the throttle body wasn't fully pushed in. Pretty sure it was the RH one but was a while ago. Not hard to check but needs the top hoses off and small hands or remove the body and push them on. No difference in performance after I noticed but no code. Current 2007 TDV8 Vogue Buckingham Blue |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 190 ![]() ![]() ![]() |
Thank you I will take a look |
