![]() | Home > Maintenance & Mods (L405) > L405 DOOR SEAL |
SmokieRRFF Member Since: 08 Feb 2019 Location: Brisbane Posts: 4 ![]() ![]() ![]() |
Hi,
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
This is probably what they would do at the dealership to sort it. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Rossy01 Member Since: 09 Mar 2019 Location: Cheshire Posts: 11 ![]() ![]() ![]() |
I am having the same problem on mine, All four need replacing. They just don't seem to fit very well |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
This really does my head in now.. there is about 5 or mode DB different when I pinch and squeeze the door in between my fingers, so it really is either the door twisted/deformed or the seals that are shot.... |
Get a 6' block of wood (like a pallet foot) and close it in your door around where your latch is... Now make 100% certain your window is open (as its double glazed and will crack!) now push some weight against the top frame of your door! Gently at first then apply more pressure, bit by bit and you'll feel the door frame give, a couple of mm at a time... Check the gap has gone and road test... If not enough, redo steps above until it fits properly |
Hi Craig
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 493 ![]() ![]() ![]() |
Did this work Charles89? 2017 Range Rover Vogue V6 Diesel 2006 Range Rover Vogue V8 Diesel - gone |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 941 ![]() ![]() |
£75k+ to buy new and resorting to blocks of wood to bend doors into shape, love it! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I had a Mercedes with the same problem - the dealer fix was exactly the one Craig suggested. Geoff |
stablemate Member Since: 16 Sep 2020 Location: Lincolnshire Posts: 32 ![]() ![]() ![]() |
Sorry to hijack the thread but does anyone have the part number for the door seal that runs around the drivers door? Mine has been ripped and damaged so ideally need to replace it. - Corris Grey 2017 Range Rover Autobiography SDV8
