![]() | Home > Maintenance & Mods (L405) > How to code rear lights on with DRLs |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You can't Charles... You would need to hard wire them!
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I converted it myself Craig.
Front & rear? Or is it just the rears you’ve done sir? |
Rear I did over the last two days. And it required some fettling as I have the electric tow bar and the parts were from a 2019 with no tow bar.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
you could ask Pat @ GAP to let you have the full un-tested beta list for your tool....it might have the correct setting in there.. ... - .- -.
Ah excellent!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/member-patgapinnov.html
I already have it Stan and you cannot, hence my earlier post ![]() The Bus changes dramatically on 15MY then 16MY cars and the LCM & BCM are entirely different hence it NOT being possible sir ![]() ![]() You can however simply feed the lamp with an ignition live and solder in a one way resistor so the rest of the car does not get the feed... Oh and another in the feed wire so as not to back feed when the side lights illuminate ![]() |
Be a little careful changing/messing with unsupported "stuff" with the IID on the 405 as they can cause you HUGE problems... Ask me (& Pat) how i/we know... ![]() ![]() ![]() |
