![]() | Home > LPG > Which spark plugs are best for LPG? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 ![]() ![]() |
Just use the ones that are spec'd for the car, you gain nothing by buying specials for lpg ime |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 835 ![]() ![]() |
As above standard plugs |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 ![]() ![]() ![]() |
+ 1
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 ![]() ![]() ![]() |
I can't give a logical reason for it but when I did a lot of LPG work I always found that NGK plugs were better than anything else. It was common to find that a set of NGKs would work fine on a car that had misfires on gas with other plugs.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 ![]() ![]() ![]() |
NGK's website suggests the recommended plugs are BKR6EQUP, if you want an upgrade go for BKR6EIX and for LPG use LPG1.
Standard plugs might be fine but why not use the NGK recommend LPG plugs? |
Ended up using Bosch 4 prong Platinum plugs - which seem to be exactly the same as the BMW ones that came out. Part number FGR7DQP or 0242236562.
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester Posts: 193 ![]() ![]() ![]() |
Hi.
