Home > Technical (L405) > L405 Adaptive dynamics fault
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi all. I have a 2015 SDV8 autobiography, and she's just displayed Adaptive Dynamics fault so I've
lost stability control, HDC not available ETC. Are there any known issues as with the L322 top turret wires for me to look at before running into my local indie? Cheers Dave
Post #531589 20th Oct 2019 10:40pm
GraemeS
Australia
That will be caused by a brake system fault, possibly a failed ABS sensor or broken wire or a failed steering angle sensor.
Post #531593 21st Oct 2019 2:57am
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Is this at startup or while driving? Does it clear after switching off/on or after a short drive?
Low battery can cause this so would be worth checking also.
Post #531599 21st Oct 2019 7:22am
It’s all guesswork without fault codes I’m afraid! There isn’t any common issues like the 322 issue you mentioned above... Well, ahem! Not yet anyway 🥴👍
Post #531603 21st Oct 2019 8:40am
diesel Dave
Hi Craig, I only have a basic code reader, but this is what it came up with, there was also a reading C0300, but it disappeared before I could screen shot it Embarassed Thanks Dave
Post #531723 21st Oct 2019 9:04pm
qwerty
Just wondering if you got this sorted?
Post #540994 18th Jan 2020 4:16pm
diesel Dave
Hi qwerty, yes I did thanks, turned out to be the seat restraint module was chucking its toys out, also battery had low voltage, replaced by the dealer and all ok now. Thumbs Up
Post #541301 21st Jan 2020 6:46pm
qwerty
Post #541324 21st Jan 2020 9:00pm
