![]() | Home > Technical (L322) > porous block. Coolant leak. As much help as possible please. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Even really bad cooks can't burn water (but I know what you mean...) .
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Sorry chaps. I don’t understand that last 2 posts??
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
Interesting Read |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
Have you put fluro dye in the coolant yet ? |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Coolant may be getting into the combustion chamber via head gasket and being 'burnt' off (converted to steam).
How long have you been topping up the coolant system, how often & what quantity?.
I hate to ask but... you are sure you put the new coolant in the hole it is supposed to go in. |
Yes buddy. Regards
Would it be possible to get a list of places that coolant could go?
Should I try this??? And if so is one bottle enough?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Get a large dose of k seal in there
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
compression test?
will a compression test help much? Also are they easy to do on a diesel v8? Regards
not sure on a diesel actually.
