Home > Technical (L322) > porous block. Coolant leak. As much help as possible please.
Page 3 of 4 <1234>
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Jamiehol wrote:
Chances that the water is being lost through evaporation in the combustion process had a diesel Passat that did exactly that no mayo signs but when it got hot water wasn’t in the combustion chamber
Post #531748 22nd Oct 2019 7:18am
Jamiehol
dazza1983 wrote:
Sorry chaps. I don’t understand that last 2 posts??
Where would the water be getting burnt?
Edited it my post to make it clear was being very lazy when I said burnt.
Post #531749 22nd Oct 2019 7:20am
dazza1983
So how would the coolant getting into the cylinders? And what test can be done to figure out if this is the case?
Cheers Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #531753 22nd Oct 2019 8:03am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
If it is a porous block the coolant wicks it’s way through the block material and into the cylinder walls, on the old 4.6 P38’s the only solution was to fit ‘top hat liners’ to each cylinder.
These then blocked the ingress of coolant into the cylinders but didn’t stop the block from being porous, unfortunately nothing can I believe.
Best of luck.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #531761 22nd Oct 2019 9:34am
dazza1983
So im going to pick the car up soon, no coolant found in the sump at all, and they have checked pipes, and egr cooler and oil cooler etc.. So im kind of at a loss now..
I may be clutching at straws but im hoping it may have been a air lock or something?
Ive ordred some uv dye and i may put that in and have a hunt around with a uv torch..
Other than that im not sure what to do? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531763 22nd Oct 2019 10:13am
AndyW970
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Had coolant loss issues on a number of V8 Classics with the 3.9 engines - turned out to be coolant getting past head gaskets into the cylinders. To diagnose I found that along with a compression test , taking a look in the cylinder with a boroscope showed the face of the piston in the effected cylinder to appear like it had been steam cleaned compared to the good cylinders. One I had did pressurise the cooling system with combustion gasses (quite spectacularly) the other didn’t. Not sure how easy it is to get a look into the diesel V8’s as I’m new to these engines but I’d have thought you could get a look in by removing the glow plugs?
Hope you get it sorted
Post #531766 22nd Oct 2019 11:01am
Jamiehol
Cheers
Either through a crack in the head or block or a head gasket failing at a water way into the combustion chamber.
Test wise a sniff of the coolant with a sniff tester would be a start to see if there is combustion gases in the coolant.
Post #531768 22nd Oct 2019 11:25am
dazza1983
Sniff test was done and came back ok.. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531770 22nd Oct 2019 12:20pm
dingg1
So you either have a tiny leak externally which is not apparent on the myriad of possible places it could be observed readily on or you have a small leak into a cylinder.
I know what my money is on.
Try the k seal option and see how it goes instead of throwing more money at it than it needs.
Post #531774 22nd Oct 2019 12:50pm
dazza1983
Ive ordred some UV dye and im going to put that into the coolant and see what happens,
Im also looking at extended warranty which may be good if it is head gasket etc Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531776 22nd Oct 2019 1:08pm
dingg1
Good luck.
But if its in an inaccessible place and the leaks so slight the dye will not show.
Post #531778 22nd Oct 2019 1:27pm
dazza1983
I don’t know anything about this k seal or other leak stoppers.
Are they safe to use or are they a bodge? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531782 22nd Oct 2019 1:54pm
DrRob
Bodge in my book. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #531790 22nd Oct 2019 3:20pm
I would just drive the car and keep checking the coolant level daily when cold and see what happens. Thumbs Up
Post #531796 22nd Oct 2019 4:05pm
Brian Considine
I used to think that it was a bodge until I used some Barsleaks in a Transit to get me home once - it stopped the leak after a few miles & was still holding some 100,000 miles later..............
Not bad for a bodge & in my mind worth trying. 2003 Range Rover Vogue TD6
Post #531797 22nd Oct 2019 4:07pm
Page 3 of 4 <1234>
