![]() | Home > Maintenance & Mods (L322) > Brake Bleeding 4.4TDV8 - engine running? |
you dont have to bleed the brakes if you're just changing pads....theres a 'how to' in the wiki.. ... - .- -.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
To change old/thin pads to new/thick pads I need to open the bleeder to not push the old fluid up and back into the reservoir.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
use vacuum, fast an easy/
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
If you wedge a block of wood on the brake pedal BEFORE you disconnect the caliper you won’t lose anything (if that’s what you are doing?) Current stable:
