![]() | Home > Maintenance & Mods (L322) > pattern vs OE parts - opinions please |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8111 ![]() ![]() ![]() |
FWIW my general attitude to pattern parts is to consider the cost of doing the job twice.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Assuming you are thinking belts and pulleys.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Thanks guys.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
Bearmach are pretty well known - do a search on here and there are lots of opinions including those of professionals.
John, my view on Genuine parts is to buy what you can afford!
thanks Mike.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
We have both Britpart and Bearmach accounts
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
[b]Cam-Tech-Craig[/b]
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
theres all sorts of scams go on in replacement parts.
No sir, its something JLR have done for years... We often have batteries fail for example and as many of our customers are spread out all over the UK, they simply take their car to their local main agent, the main agent contacts us for the purchase/sales receipt then changes the customers battery for free (including labour)... The secret is to ask your JLR parts supplier to put either your reg or VIN on the receipt. This they usually expect as a minimum to prove you purchased the part for that car... Not your brothers etc etc! |
Thanks Craig
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Had the same Moog part issue. I didn't realize Moog makes an economy line now and that is what I ordered. Never wore out the better line of Moog parts. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2261 ![]() ![]() ![]() |
I always stick with jlr parts except in one place - when the one parts are the same manufacture and 1/3 of the cost... the denso alternaterwas around 600 dealer and 200 own (both denso) same with my Bosch super charge colling pump Current stable:
Don't forget though Dan, if Denso (for example) make a part for JLR then it has to meet their standard! If Denso then make a much cheaper part under their own brand name, there may well be some corners cut? Im not saying its a rule of thumb! But well worth thinking about when ordering!
