![]() | Home > Technical (L322) > Suspension on high |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
it shouldn't sink.
also, check if the whole car is sinking or just one wheel (which might give the impression that the whole car is sinking) as this might help to diagnose |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Thanks for the reply mate. The compressor only runs occasionally. Obviously longer if I've lowered it myself and it needs to refill to raise it again. The front end lowers by about 50mm and the back end marginally when it does it. I will do as you suggest and measure all three settings. I have a feeling that the front right sensor has about half the voltage of the other three when I put my code reader on. |
ive never tried this and happy to be flamed if it wont work:
Good idea. Will give it a go when the weather dries up. Thanks. |
