Home > Maintenance & Mods (L405) > Fully floating high performance replacement discs for L405 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7751 |
First I've heard of warping discs being a particular issue......
26th Oct 2019 4:24pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
where did you hear about warped discs on the L405 Charles? ... - .- -.
26th Oct 2019 4:49pm |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Main dealer told me it's a common issue... so I did some reading and the L405 and L494 sharing the same brembo set up suffer this issue supposedly..
26th Oct 2019 8:08pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1689 |
You will struggle to find 2 piece discs
26th Oct 2019 8:24pm |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
cooling has nothing to do with keeping the brakes from warping, it has to do with mitigating performance loss under heavy use. They also don't technically warp! If the brake is warped, it is just cut uneven from use. You can have the rotor turned or replace. Your rotors will almost certainly be uneven if you do a brake job and only swap out pads. You should have your rotors turned or replaced every time pads are swapped. If you're getting uneven wear that quickly, something is up with your brakes.
26th Oct 2019 9:28pm |
The PistonHeads thread seemed to be just 1 or 2 people and talking more about L494's than L405's.....
26th Oct 2019 10:44pm |
Thank you all for the detailed replys
27th Oct 2019 8:35am |
I've only ever used genuine on my L405
27th Oct 2019 9:20am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
a link to start you of/
27th Oct 2019 9:33am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
its my understanding that brake discs rarely warp. the problem is uneven transfer of brake material onto the disk which results in a 'warped disk' feeling afterwards and the bigger the disk diameter the greater the liklehood of this happening.
27th Oct 2019 11:10am |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 736 |
Discs can also become warped if, when changing wheels, tightening torque is not respected! 2019 Vogue P400e |
27th Oct 2019 12:31pm |
for sure this is your problem then, I bet you noticed a world of difference with fresh rotors. also, don't use the old pads as it'll just be the same problem in reverse. Fresh rotors, fresh pads and I'm sure you'll have smooth braking for tens of thousands of miles. |
27th Oct 2019 11:00pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
L405's have a habit of throwing the lower front arm bushes! This will/can give you the appearance/feel of warped disks believe it or not! Its basically the wheel/suspension moving backwards and forwards causing the feeling of warped discs!
27th Oct 2019 11:45pm |
